whoamireally1
Sep 01, 2022Aspirant
GS308e Admin page unreachable
I am having an issue where I can't access the Admin page for GS308e switch. I have ATT Fiber modem/router. I have the modem/router connected to the switch and multiple LAN connections off the switch....
whoamireally1
Is the Nighthawk operating as WAP connected to the switch or to the router? Do the switch discovery tool find the GS308E?If Yes, is the IP address same with your device IP?
It is connected to on the load side of the switch via a LAN connection on the 2nd floor. All the house LAN connections are connected to the switch at the ATT router/modem. The set-up is ATT Fiber router/modem -> Switch -> House Lan Connections and upstairs Nighthawk WAP -> upstairs laptop.
My laptop is connected to the Nighthawk router on the 2nd floor in one of its ports for "ethernet connection". When I use the tool, it finds the switch but the Admin page doesn't show up.
My ATT router/Modem does not show the switch in the list of devices connected to it.
We have to make sure that the GS308E and WAP gets an IP from the router and your device connecting to your WAP should get an IP as well from the router. You can access the switch via web browser but not by using the Insight App or Discovery tool.
I cannot access the switch via web browser. It gives me an error saying it timed out.
You can get the IP address and use the browser to login.
Marc_V
Sep 05, 2022NETGEAR Employee Retired
What's the model of your modem/router? How many ports does it have? If the switch directly connected it should get an IP from the router. If it's not there might be a problem with the switch or how it is connecting to the router. Is it brandnew?
- whoamireally1Sep 05, 2022Aspirant
What's the model of your modem/router? Nokia BGW320-505
How many ports does it have? 2
If the switch directly connected it should get an IP from the router. If it's not there might be a problem with the switch or how it is connecting to the router. Is it brand new? It's connected to the router/modem, and from the switch, it connects other rooms in the house via ethernet. Switch was purchased in October 2021.
- Marc_VSep 06, 2022NETGEAR Employee Retired
Checking the router model it has 4 Ethernet ports in which 1 is a 5Gb port. This is the router you have right? The switch connects to the yellow ethernet ports? Since the switch connects to the router and all devices connecting to it gets Internet and the WAP connects to the switch as well?
I can't say that the switch has the problem but getting Support to check on the issue why your switch does not get DHCP address after factory reset would be the best option, so they can send RMA if needed.
- badazzbroJul 31, 2026Aspirant
This is for user with the Nokia BGW320-505 modem. I had the same problem, your default IP addrs for your switch was given a new IP by the Nokia BGW320-505 modem. To locate the new IP address number for the switch. You have to log into your Nokia BGW320-505 mines was 192.168.1.254 via the browser. Once in the router go to (Home network) than under IP Allocation section locate you switch in the (IPv4 Address / Name column) then you'll find the new IP# looks like this 192.168.1.100 / NETGEAR with the same mac address as yours. Then use the netgear tool to finish the install.
