LoBer
Jul 08, 2024Tutor
GS308E suddenly stopped working with power led blinking
Hi everybody. My device (Netgear GS308E) suddenly stopped working. When powered on, the power led and the top right led on ethernet port #8 blink fast both. No other activity on other leds. No po...
- Jul 23, 2024
Head to https://my.netgear.com/
Scroll to the end of the page.
Customer Care - Contact us https://www.netgear.com/about/contact-us/
Get Support https://my.netgear.com/support/contact.aspx
Open a Support case
Contact us by Phone
Note: This is the number shown for Switzerland and does not apply to random other markets.
schumaku
Jul 18, 2024Guru - Experienced User
The GS308E (see the Data Sheet) does come with a five year limited lifetime warranty for the original buyer. Head to https://my.netgear.com/, select your registered device, and follow the [Request Hardware Support] process.
LoBer
Jul 18, 2024Tutor
It looks my product is till under warranty... I bought it 4 years ago
But on Netgear site there is no option to contact Netgear itself regarding the issue.
The original seller, Amazon, states it is not under warranty any more.
I don't know what to do.
- schumakuJul 18, 2024Guru - Experienced User
Your switch is already registered and listed on my.netgear.com? You can always follow the process as described, there is no need to contact Netgear Support on a different channel, no email, chat, or phone support is required to start this process. You will receive the instructions on how to reach Netgear Support including a ticket number and phone number to call by email on case this is required for the warranty exchange.
Amazon is not involved, this is a pure manufacturer warranty case.
- LoBerJul 21, 2024Tutor
Hi, thanks for your support.
Yes the device has been registered from the beginning on mynetgear.com.
If I follow your instructions I get the following (see image attached).
I have no problem in giving you the serial number (I don't know if it's good habit here)
- schumakuJul 21, 2024Guru - Experienced User
I'm not Netgear, so please don't, nothing I could do with the correct number.
Retry later, or another day.
