litlhous
Aug 23, 2020Initiate
GS308E won't update firmware
I'm trying to update the firmware on my GS308E switch. It's running V1.00.01 and I'm trying to go to the latest: GS308E_V1.00.05EN. Once the transfer status bar gets to the end it hangs. If I wait lo...
- Aug 23, 2020
I found a post on a different model switch that had a similar issue. I was able to upgrade by using Internet Explorer.
litlhous
