sachinchain80's avatar
Oct 21, 2022
GS308EPP daisy chain
Hi All
I have a GS348 (48port), i will add a GS324 (24port) and presume they should daisy ok?
I will need an 8 Port POE switch as well-would the GS308EPP daisy ok or another netgear 8 port switch-unmanaged is fine
Thanks
  • schumaku's avatar
    schumaku
    Yes, of course. Depends what you expect performance-wise through the complete daisy-chain however.
    • sachinchain80's avatar
      sachinchain80
      Thank you
      Basic small business, only running low perfm PC and a couple of POE access points
ProSupport for Business
