mike698
Feb 18, 2024Star
GS308EPP POE switch web interface does not display properly
The device has been connected for about a year without issue, but when I go to the web interface now, I see a jumble of unreadable options:
- Feb 23, 2024
Still suspect there could be multiple systems on your LAN with the same IP addresses like the two GS308EPP,
The Netgear Switch Discovery Tool does make use of a pure L2 protocol (NSDP) so the discovery of the switch, and gathering switch names, models, firmware versions, et all does run almost indepedent from IPv4. The point is: This does not proof the addresses are not occupied my multiple devices. In case the IP addresses are coming from DHCP, please create new MAC-IP reservations on your DHCP server, or push complete different IPv4 addresses to the switch config. The level of issues - different UI and details unlikely related to GS308EPP switches, and failing Web UI - does almost proof something fishy.
steffen-heil
Jan 02, 2026Initiate
What was the actual solution here? I do have the same problem...
- mike698Jan 02, 2026Star
Hi steffen-heil - its been a while but if my recollection is correct to resolve the issue I preformed a factory reset on the switch, then upgraded the firmware to resolve the issue.
