jmail92
Sep 18, 2025Aspirant
GS308Ev4, GS305E - Help with uplinks/downlinks
Could I please have some help or confirmation that I have these setup correctly? I'm weary that they are because I sometimes have trouble connecting to the admin interfaces on these switches. I've ...
schumaku
Sep 18, 2025Guru - Experienced User
That's not a question of up- and downlink - all ports are the same, there is no designated uplink port.
Much more, the future network designers must understand that these small Plus switches are not built on a managed cores, so the Web UI can ONLY operate untagged, Tagged frames are ignored by the switch uC handling the the WebUI.
These are not Smart Managed Switches or Managed Switches where the CPU port can be configured for a management VLAN.
You must ensuite the management or admin "VLAN" must be able to reach these switches on an untagged connection. Said that, used need to understand his restriction on designing their networks.
If you desire to design and implement your network with a management VLAN, these switch models are not for you. This is the price you pay by deploying these very inexpensive Plus switches, but plan to implement a business class network.
When I see uplinks and downlink ports carrying tagged ports only, it's obvious you won't he able to manage (== administrate) the switched due to this limitation.
jmail92
Thanks for the reply. Ok, bit of clarification. This is a home network. And apologies for using the wrong up/down link terminology. It just made sense to me. Does the above configuration require a management VLAN?
So the setup of GS308Ev4-1 for VLAN1 maybe needs to be:
