madars
Oct 21, 2022Aspirant
GS308T LACP Setup problem with TrueNas Server
Hello everyone ,
I try to settings up the LACP protocol with my TrueNas Computer .
After I configured all port as should be , no networking connection between GS308T to TrueNas .
Model Name - GS308T
Boot Version - 1.0.0.1
Software Version - 1.0.5.6
All settings for LACP side of GS308T upload here inside pdf file.
The GS308T working perfectly beside the LACP feature .
I will want to tag (Untagged) port 7/8 to VLAN40 at my house .
I try to figure it out , where is my mistake in term of settings LACP feature .
Appreciate any help or suggestion thanks a lot .
Welcome to the community!
Could you also provide the LACP configuration for the TrueNAS? Also, please verify if the LACP configuration on the TrueNAS has the same hash mode as the switch.
Under PVID Configuration on the switch, please click on LAG and see if AsrockNas1 has PVID40.
JeraldM
NETGEAR Community Team
- JeraldMNETGEAR Employee Retired
JeraldM
- madarsAspirant
