PabloD's avatar
PabloD
GS324T Missing interface Ingress Rate Limit
Hi.
For Some reason the "Interface Ingress Rate Limit" column is not showing up on  the CoS Interface Configuration Settings of a newly purchased GS324T switch.
It should be there according to the user manual but it is not.
I only see the Interface Shaping Rate setting which controls the download speed.
I upgraded to the latest firmware and it is still missing.
We specifically need this functionality (and The Interface shaping Rate) to limit both upload and download speeds on the ports.
Any ideas of how to sort this?
  • schumaku's avatar
    schumaku
    Just to avoid or trigger some finger pointing: What Web browser (aside of Internet "security" and basic operation system) is in use there?
    • PabloD's avatar
      PabloD
      Any browser.
      It's all the same.
      It looks like the "ingress rate limit" setting was removed on newer versions.
      I bought new switches and I have now a GS324T and a GS724T v4 and none of them have it.
      The functionality is listed in the user manuals of the GS324T and GS724T but it seems to not be listed on the GS724T v4.
      I am not sure when or why it was removed and if I can revert back to a firmware that still has it.
      • PabloD's avatar
        PabloD
        So.
        I tested earlier a GS716T that had this functionality (both ingress and egress rate control).
        I needed something with more ports so went with the GS324T and found it doesn't have it although it does show up in the user manual.
        I got a GS724T v4 thinking maybe it's available only on the 700 family but it's also missing.
        Apparently it used to be available on the GS724T v3 (acording to the user manual) but I canot get my hands on one of those at the moment.
        I still do not know why or when this functionality was removed or what current model still has it.
        While I would prefer to use Netgear switches, at this point I am looking a Zyxel ones that do have this available because I can not get an answer from Netgear on what model will have this.
ProSupport for Business
