nzbiship
Aug 18, 2022Aspirant
GS324TP PoE Power Status Off - Can't enable
I have 4 5w Poe devices on ports 1-4. They were working fine with FW 1.0.0.38.
I upgraded to 1.0.0.43 and now they are not receiving power. (I did not reset settings to factory default).
On setting page System -> PoE -> Advanced -> Poe Configuration, everything is at default and Power Status is OFF.
On setting page System -> PoE -> Advanced -> Poe Port Configuration, everything is at default, all ports show Status Disabled (No Error).
CPU usage is 16%.
I've power cycled a few times.
How can I re-enable PoE?
Thank you for any help!
- JeraldMNETGEAR Employee Retired
Welcome to the community!
If setting the switch to factory defaults is not an option, have you tried reverting the FW back to v1.0.0.38 to see if the PoE works again?
JeraldM
NETGEAR Community Team
- nzbishipAspirant
Thanks JeraldM.
I will factory reset first and see - thanks.
