pdobrien3
Jan 28, 2017Aspirant
GS516TP VLAN HELP!!!!
Hello everyone, First, all my networking knowledge has been learned through trial and error and the internet. With that said, I have taken on quite a tasking and am at the end of the road if I c...
- Feb 04, 2017
Pretty sure I fixed it Yaaaaaaa,!!
i created vlan10 and bridged it with the LAN ports on the RT-AC66Us. Apparently the management vlan1 on the Netgear switch was causing me problems. I couldn't tag vlan1 for the ports I needed on the switch. Once I moved everything to another vlan, went smooth as silk.
Carl_z
Feb 04, 2017NETGEAR Expert
Hi pdobrien3
I aggre with DanaA 's suggestion. And there more things I want to known.
As you said "WORKS GREAT when the routers are connected to each othe" , in this condition, did you connect two ASUS AC-RT66U through port 2 ?
And what the configuration of the connected ports between two ASUS AC-RT66U ?
Best Regards
Carl
Netgear Employee
pdobrien3
Feb 04, 2017Aspirant
I am sorry if my reply to DanaA's post is not clear. My setup is in fact in compliance with DanaA's suggestions. Also, when the RT-AC66Us are connected directly, without the Netgear switch, they are both connected through port 2. Following is my port/vlan setup on the two RT-AC66Us. I would be happy to provide this for the GS516TP but don't know how.
nvram show | grep vlan.*ports
vlan1ports=1 2t 3 4 8*
vlan2ports=0 8u
vlan14ports=2t 8
vlan15ports=2t 8
nvram show | grep port.*vlans
port5vlans=1 2 14 15 16
port3vlans=1 18 19 21
port1vlans=1 18 19 21
port4vlans=1 18 19 21
port2vlans=1 14 15 16 18 19 21
port0vlans=2 18 19 21
nvram show | grep vlan.*hwname
vlan2hwname=et0
vlan15hwname=et0
vlan1hwname=et0
vlan14hwname=et0
thank you for your response,
Dan
- pdobrien3Feb 04, 2017Aspirant
- DaneAFeb 05, 2017NETGEAR Employee Retired
Thanks for the update. I'm glad that creating VLAN 10 and moving everything to VLAN 10 make it work. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
- pdobrien3Feb 05, 2017Aspirant
Thank you. Done.
