GaACETech
Dec 06, 2020Guide
GS716T - Fiber Module
Two new small offices (<10 devices each). Fiber between the two switches (< 500'). Purchased the GS716T. The fiber is being terminated with ST connectors. What fiber modules are sugg...
schumaku
Dec 06, 2020Guru - Experienced User
Hi,
Absolutley industry standard using SFP modules for fiber links 8-)
The hard work first: You have to figure out what kind of fiber is in place.Markings and colouring does help.
Fiber Type Color Code
| Non-military Applications | Military Applications | Suggested Print Nomenclature | |
| OM1 62.5/125µm Multimode | Orange | Slate | 62.5/125 |
| OM2 50/125µm Multimode | Orange | Orange | 50/125 |
| OM3 50/125 µm (850 nm Laser-Optimized) Multimode | Aqua | Undefined | 850 LO 50/125 |
| OM4 50/125µm (850 nm Laser-Optimized) Multimode | Aqua/Violet | Undefined | 850 LO 50/125 |
| 100/140µm Multimode | Orange | Green | 100/140 |
| OS1/OS2 Single Mode | Yellow | Yellow | SM/NZDS, SM |
| Polarization Maintaining Single Mode | Blue | Undefined | Undefined |
Based on this, you can select single mode or multimode SFP module (Netgear's reference listing -> https://www.netgear.com/business/wired/switches/accessories ) - for SFP look for 1000BASE-SX AGM731F or 1000BASE-LX AGM732F and order the matching patch cables. An LC/PC connector is required on the SFP module end.
Needless to say, beyond of the right fiber technology, the same frequency (colour) is required on both ends.
Netgear does not enforce exact vendor IDs (very different on the more expensive networking hardware makers!) and does commonly work with third party OEM modules.
