AndySmith67
Jan 05, 2021Follower
GS724 - MIB file download
Hi,
I have been looking for the MIB file for the switch above. I can't find this in the download section of the site. I have found that the question has been asked before but the links to the actual file has expired.
Could you re-create the link so that I can collect the file? Thanks in advance.
Andy
When we're heading to https://www.netgear.com/support/ and type GS724 not less then 12 different models show up.
For the tagged GS724Tv4 the MIB are port of the downloads on https://www.netgear.com/support/product/GS724Tv4.aspx#download
The crystal ball is on a holiday...
- DaneANETGEAR Employee Retired
Welcome to the community! :)
You can download the MIB file (given the corresponding firmware version) of the GS724Tv4 switch here.
If ever your concern has been addressed / resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
