chrisn7599
Sep 03, 2023Aspirant
GS724T - can't get VLANs to work over LAG connected to Fortigate
Greetings, I have a GS724Tv4 that I can't get VLANs to work for using a LAG interface to a Fortigate firewall and am looking for assistance. The GS724T has ports 23-24 configured as LACP and...
- Sep 03, 2023
chrisn7599 wrote:
- I have a VLAN-204 set up on the switch with ports 7-9 marked as untagged members and the LAG marked as a tagged member.
- I have a PC plugged into port 9 with an IP address of 192.168.2.67 but I cannot ping the Fortigate 192.168.2.65 address.
Have the PVID set to 204 for the ports you intend to use untagged access ports?
schumaku
Sep 03, 2023Guru - Experienced User
- chrisn7599Sep 03, 2023Aspirant
That was the issue. I had not set the PVID for the untagged ports. It is working now.
Thanks!
