Nintendo_1889
Mar 31, 2021Follower
GS724T ARP Table?
I have a circa 2005 gs724t running V1.0.3_33. How do I upgrade the firmware? Would the firmware upgrade add an arp/address/mac table?
schumaku
Mar 31, 2021Guru - Experienced User
Based on model and current firmware, one might guess it's a GS724Tv2h2 platform as shown there -> https://community.netgear.com/t5/Smart-Plus-and-Smart-Pro-Managed/GS724T-model-version-for-firmware-upgrade/m-p/1611788 - however, better let DaneA check the serial number before breaking this oldie with a wrong firmware.
Not sure how much luck you might have with the Smartwizard Utility on modern Windows systems however.
As these are L2 switches, it's very unlikely there will be any ARP table made available.
