becko's avatar
becko
Follower
Aug 11, 2016
GS724T does it support LACP- I want to enable Port Trunking on Buffalo NAS Backup Drive
I have a Buffalo Terrastaion connected to LAN  with 2 discreet Gigabyte Ethernet connections to GS724T.
To improve bandwidth I can enable Port Trunking using Dynamic Link Aggregation on Terrastation, but in order for this to work LACP requires implementing on the GS724T.
I am now out of my technical depth and would appreciate some advice oe help on if it is possible to  to do this and if so how?
Is LACP available on the GS724T?
If so is it a Switch option, or is it implemented on the specific ports the NAS drive is connected to.
Thanks and eternally grateful
Becko
  • Hello becko,
    Welcome to community!
    There is an option on the switch to enable Static or LACP LAG. You'll have to select this upon creating your LAG membership. Please refer to page 94 and 99 of the User Manual.
    Let us know if this helps.
    Thanks,
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello becko,
    Thanks,
  • JohnRo's avatar
    JohnRo
    Hi becko,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    Thanks,
ProSupport for Business
