Fulman
Mar 27, 2018Aspirant
GS724T smart switch version?
Hello, I have just got a 2nd hand GS724T smart switch and want to check that the firmware version is the latest one, however i can't find the version number of the switch anywhere on the unit or ...
- Mar 28, 2018
Dear Ian,
Not fluent with a potentially older factory designation scheme I'm afraid.
According to the firmware version, it looks like a GS724Tv1 -> https://www.netgear.com/support/product/GS724Tv1.aspx#Firmware%20Version%201.2.3?cid=amb - and it has some updates pending.
Fulman
Mar 28, 2018Aspirant
Hi Schumaku,
Thank you for the reply. Not sure which label you are meaning the only label on mine is on the bottom and starts GST714 and ends 000383. The current firmware version is V1.1.0(0416) and protocol version 2..001.002,
regards
Ian
schumaku
Mar 28, 2018Guru - Experienced User
Dear Ian,
- FulmanMar 28, 2018Aspirant
Hi Schumaku,
That worked perfectly thank you. It's now on the latest firmware version.
regards
Fulman
