oheli1
Nov 10, 2018Aspirant
GS724TP Web-GUI don't display UNITS
Hello,
I'am a bit frustrated cause I didn't succeed in configuring the switch for a small office.
The web-GUI seems to be buggy. It is not possible to tag/untag the ports/lags because it isnt...
- Nov 21, 2018
Hi schumaku
thanks a lot for your support.
Finally it works with IE11 and "compatibility mode".
It is not realy smooth and time efficient but it works for most menues.
Only the lag-membership couldn't be activated, so I was not able to double the two ports vor 2GB to the NAS. I very often the menues freeze and you have to reload the page, but patience will be rewarded.
Best regards; Eli
schumaku
Nov 10, 2018Guru - Experienced User
The GS724TP is an elderly 10+ years old switch model. Or do we talk of the GS724TPv2? What firmware version?
Yes, I've seen some similar reports here in the community, this might be indeed a Web UI incompatibility with modern browsers. Or in a few case a problem with some Internet "security" software corrupting JavaScript. IE might be workable. With some more information (what you see or what you can't see - compare https://kb.netgear.com/29997/How-to-create-Layer-2-VLANs-on-NETGEAR-ProSAFE-Switches ) somebody from Netgear might be able to follow up and make engineering check the problem, and fix it.
oheli1
Nov 12, 2018Aspirant
Hello schumaku,
thank you for answering: yes, it's about the old one.
I already tried Firefox Version20, but no success.
I will try on old IE :-)
Does anyone know how to do via mcli or isn't this possible at all?
(I already got a promt and changed the password through telnet.)
Best regards
oheli
- schumakuNov 12, 2018Guru - Experienced User
bradleyv LaurentMa please ensure engineering is updating the still supported switches Web UI to be workable on modern browsers. To many customer sites have no more Windows, so no more Internet Explorer.
- oheli1Nov 14, 2018Aspirant
It is not a problem of IE. As I mentioned I even tried Firefox version 20.
To be honest I'am wondering how it could be, that NETGEAR doesn‘t provide an update for this switch.
24 GB-ports POE is not the worst one, it is still usable in smal business.
And: lifetime warranty, for what ??
Best regards
eli
- schumakuNov 14, 2018Guru - Experienced User
If we manage a moderator moving this thread to the appropriate Smart / Plus / Click Switches community section we will get the ability to tag the correct model and gain the attention required.
