oheli1
Nov 10, 2018Aspirant
GS724TP Web-GUI don't display UNITS
Hello,
I'am a bit frustrated cause I didn't succeed in configuring the switch for a small office.
The web-GUI seems to be buggy. It is not possible to tag/untag the ports/lags because it isnt...
- Nov 21, 2018
Hi schumaku
thanks a lot for your support.
Finally it works with IE11 and "compatibility mode".
It is not realy smooth and time efficient but it works for most menues.
Only the lag-membership couldn't be activated, so I was not able to double the two ports vor 2GB to the NAS. I very often the menues freeze and you have to reload the page, but patience will be rewarded.
Best regards; Eli
oheli1
Nov 12, 2018Aspirant
Hello schumaku,
thank you for answering: yes, it's about the old one.
I already tried Firefox Version20, but no success.
I will try on old IE :-)
Does anyone know how to do via mcli or isn't this possible at all?
(I already got a promt and changed the password through telnet.)
Best regards
oheli
