oheli1
Nov 10, 2018Aspirant
GS724TP Web-GUI don't display UNITS
Hello,
I'am a bit frustrated cause I didn't succeed in configuring the switch for a small office.
The web-GUI seems to be buggy. It is not possible to tag/untag the ports/lags because it isnt...
- Nov 21, 2018
Hi schumaku
thanks a lot for your support.
Finally it works with IE11 and "compatibility mode".
It is not realy smooth and time efficient but it works for most menues.
Only the lag-membership couldn't be activated, so I was not able to double the two ports vor 2GB to the NAS. I very often the menues freeze and you have to reload the page, but patience will be rewarded.
Best regards; Eli
JohnC_V
Nov 15, 2018NETGEAR Employee Retired
Hi oheli1,
Welcome to our community! :)
I hope this article helps: The VLAN and LAG configuration screens do not display correctly on my switch
