grubik
Aug 22, 2025Tutor
GS724TPPv3 (FW v6.1.0.10) PoE MIBs error
Hi,
I'm trying to check/enable/disable PoE on switch ports via SNMP. The problem is that I'm using MIBs for firmware version 6.2.1.12 but my switch has firmware version 6.1.0.10 and I do not wish to update the switch firmware version.
When I try to "walk" PoE MIBs I get the error:
> snmpwalk -v2c -c <COMMUNITY_STRING> <IP> iso.3.6.1.2.1.105.1.2.1.2
Did not find 'transmission' in module SNMPv2-SMI (C:\usr\share\snmp\mibs/EtherLike-MIB.txt)
Unlinked OID in EtherLike-MIB: dot3 ::= { transmission 7 }
Undefined identifier: transmission near line 118 of C:\usr\share\snmp\mibs/EtherLike-MIB.txt
POWER-ETHERNET-MIB::pethObjects.2.1.2 = No Such Object available on this agent at this OID
Additionally, when I try to check all available MIBs, the output stucks on following:
> snmpwalk -v2c -c <COMMUNITY_STRING> <IP> 1.3.6.1.2.1
Q-BRIDGE-MIB::dot1qForwardAllForbiddenPorts.4089 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Timeout: No Response from <IP>
Thank you in advance for reply!
Solution was to update Firmware to the latest version and download latest MIBs.
And you seriously ask for some magic solutions please? This is where a part of your problem does start ....
- grubikTutor
So the solution is just to update firmware?
- grubikTutor
Yes, MIB and Firmware are firmware version specific. Great you resolved with a simple firmware update on your switch!
