jkucukov's avatar
jkucukov
GS724TPv2 1000 BASE-X port options
Hi, new to the community looking for options :)
I’ve got the GS724TPv2 PoE+ across 24 ports plus 2 extra 1000 BASE-X empty slots, the extra 2 x 1000 BASE-X empty slots I don’t plan on using and wondering if they can be utilized for a similar purpose to plug to a NAS with patch cables.
Online, I find that there are options for 1000 BASE-T transceiver modules in RJ45 to run patch cable to other devices (if possible?).
Million dollar question, can the 1000BASE-T SFP Copper RJ-45 Transceiver Module be plugged in a 1000BASE-X slot? I'd like to use them as connections to my ReadyNAS.
Thanks,
Yas
  • Hi jkucukov,
    Welcome to NETGEAR community!:smileyhappy:
    We have official SFP Transceiverfor 1000BASE-T and called AGM734.
    GS724TPv2 also support AGM734 to work in SFP slot.
    Please find more details information from following screenshot:
    May the solution help you.:smileyhappy:
  • Hi jkucukov,
ProSupport for Business
