btwohy
Jul 28, 2021Aspirant
GS724TPv4 PoE Enable/Disable?
Hey Everybody, I am trying to Enable PoE here and can not find the option on the web server of the device. Any suggestions??? Thanks!
schumaku
Jul 28, 2021Guru - Experienced User
GS724TPv2 I guess - it's the highest hardware version AFAIK.
24-Port Gigabit (Hi-Power) PoE+ Ethernet Smart Managed Pro Switch with 2 SFP Ports and Cloud Management GS724TPv2 and GS724TPP User Manual p.92./93 .... on the port list, PoE Admin mode Enable or Disable:
8. From the Admin Mode menu, select the administrative PoE mode of the port:
•Enable. The port’s capacity to deliver power is enabled. This is the default setting.
•Disable. The port’s capacity to deliver power is disabled.
