DougShuffield's avatar
May 21, 2019
GS752TPv2: POE enable / disable via SNMP
I noted there is an existing thread on this topic in german that ends with a private message (https://community.netgear.com/t5/Smart-Plus-Smart-Cloud-Switches/Switch-GS752TPv2-POE-Admin-enable-disable-via-SNMP/m-p/1647688#M521)  which is completely unhelpful so I am starting a new thread.
  I need to be able to remotely enable / disable POE on ports via SNMP (or whatever other means is available on this switch).  I have a GS752TP on which I can do this without issue via SNMP, but on the newest model I received, this capability does not seem to be supported nor is RFC-3621 listed in supported MIBs on the switch.
Is there a means to remotely enable / disable POE on a per port basis on this switch?
Doug
  • Just wanted to follow up saying that I managed to resolve the issue by rebooting both the cable modem and the router in sequence leaving the MAC at the PCs. I strongly suspect that the XR500 router was not at fault for the issue but rather that for some reason the ISP/modem capped ipv4 traffic until the reboot.
    I am now running with QoS and ipv6 fully enabled without any issues and get equivalent speed tests over both ipv4 and ipv6.
ProSupport for Business
