btwohy
Jul 28, 2021Aspirant
GS724TPv4 PoE Enable/Disable?
Hey Everybody, I am trying to Enable PoE here and can not find the option on the web server of the device. Any suggestions??? Thanks!
btwohy
I see how to do it on the v2 model. I do not have that model. I have the v4 model. Does it even have PoE?
schumaku
Jul 28, 2021Guru - Experienced User
As per https://www.netgear.com/support/ the only GS724xxxV4 is the non-PoE GS724Tv4 https://www.netgear.com/support/product/GS724Tv4.aspx
While talking: There is no risk in connecting any Ethernet equipment to a IEEE compliant PoE capable switch. Netgear does bot make any strange so called passive PoE PSE where voltage can ve applied without any negotiation with the peer.
