Semen_Petrov
Oct 18, 2021Aspirant
GS724Tv3 Can't generate text configuration
Can't generate text configuration.
choose "Maintenance", next "download", next "HTTP File Download", next "Select File",
next create a file with the extension "*.stk"
This file is not intended for this product!
Why is that and how to fix it???Please help.
Do you intend to retrieve the current config file from the switch or do you have a backup config you like to push to the switch?
Be aware Netgear used a confusing logic for upload (from the switch to the computer) vs. download (from the computer to the switch) on this older switches.
- Semen_PetrovAspirant
I intend to retrieve the current config file from the switch
- schumakuGuru - Experienced UserSuspected this. On this older Netgear switch Web UI you need to use the Upload (switch to computer) control.
