joliveira-kbc's avatar
Apr 20, 2020
GS724Tv4 - top speed 100Mbps
Dear Community,
I have a GS724Tv4 which has the latest firmware version:
Product Name GS724Tv4 ProSafe 24-port Gigabit Ethernet Smart Switch, 6.3.1.34, B1.0.0.4
Serial Number 3H024B56002CC
Base MAC Address A4:2B:8C:06:3A:70
Problem: data transfers cannot go higher than 100Mbps. I tested iperf3 on a Hyper-V server, VMware ESXi and a Linux Ubuntu 16.04... Top transfer speed is always below 100 Mbps.
If I plug those servers directly to a computer transfer speed is always higher than 500 Mbps (depending on CPU and NIC).
Please, could someone help me?
Thank you.
Kind regards,
Jose
  • Hi Schumaku,
    Problem was on Ubuntu's 18.04 driver - autonegotiation was failing. Setting up 1000 Mbits full duplex on nic settings fixed the problem.
    Thank you for your help.
    Kind regards,
    Jose
  • schumaku's avatar
    schumaku
    The link speed on the ports in the data path indicate full Gigabit (Speed LED: green) or Fast (Speed LED: amber)?
    • joliveira-kbc's avatar
      joliveira-kbc
      Hi Schumaku,
      Kind regards,
      Jose
ProSupport for Business
