No_Jah
Jan 18, 2017Aspirant
GS724Tv4 all connected activity leds flashing constantly
I just replaced my recenlty deseased second hand GS724v2 for a GS724tv4 and i am bit overwhelmed with all the new settings and options. The first thing I did after unboxing the switch was updating t...
- Jan 19, 2017
I think I got it figured now.
I hadn't set PVIDs for the corresponding VLANs, all interfaces had PVID 1.
Now interface 1-5 have PVID 4, and Interface 6-24 have PVID 5.
And now the activity leds have stopped flashing for non active ports.
Is this the correct way to do this? And should the default VLAN be left as it is
Luckily I didn't change the PVID of all the intefaces at once because the switch became unreachable when I changed the the PVID on the interface I was connected to. But after changing the Management VLAN ID number I got it working again. I there to not have a speciffic Management VLAN ID so it's possible to manage the switch using any VLAN IDs?
LaurentMa
Jan 20, 2017NETGEAR Expert
Hi No_Jah
No you won't be able to access Switch Management CPU (web interface on Smart Managed switches) from other VLANs, you will access it only from the Management VLAN. This is the whole point of Management VLAN.
You say Multiple PVIDs, well this is extra information. There can be only one PVID per port (the untag traffic coming from VLAN-unaware device), that will be tagged into the corresponding PVID VLAN by the port. If you are on a PC without VLAN configured o on it, so VLAN-unaware, then yes you will be able to access Switch Management interface only from a port with PVID = Management VLAN.
On NETGEAR switches, factory default configuration is:
- VLAN 1 = Management VLAN in VLAN database
- All ports PVID set to VLAN 1
Yes, all LAGs are by default set to PVID = VLAN 1 as well.
For your question about the 26 LAGs called ch1-ch26: the Ling Aggregation Groups are provisionned in the system already. You can configure 26 different LAGs on this given switch, the first one is called ch1, the second one ch2 etc.. No physical ports are assigned to these LAGs yet, they are all empty, ready to use. If you need to form a LAG, select the first one ch1 for instance, and start configure it per your needs for link aggregation and/or uplinks.
Let us know if it helps!
No_Jah
Jan 20, 2017Aspirant
Ok, are those 26 LAGs safe to remove, I find it unneccessary to have stuff configured that are not in use.
And besides a LAG must consists of at least 2 ports to function, and since this switch have 26 posts there can be no more than 13 usable LAGs?
- LaurentMaJan 20, 2017NETGEAR Expert
These LAGs are not configured per se: they are only provisioned in the system.
You cannot remove the provisioning, again this is not configuration: they are blank if you wish.
To answer your question, sometimes a LAG can have one port configured, only. In reality, LAG capacity is equal to the switch port count on this switch for convenience. This way a port can have a configuration A as a physical port, and a configuration B provisioned under a 1-port LAG that is switchable by enabling or disabling the LAG.
- No_JahJan 20, 2017Aspirant
Ah, ok. I think I understand.
Thanks you for your help, and your patience.
