Warkiller102
Dec 07, 2016Initiate
GS724Tv4 two times registered in my account
Hello, I have just registered my new GS724Tv4 switch, on the my.netgear.com site, unfortunately, it is now added twice. Is there a way to delete one of the two (identical)? Best regards War...
- Dec 08, 2016
Hello Warkiller102 and Tmaster100,
Welcome to the community!
Just had some issues deleting them but I'll update you as soon as it's done. The system don't usually allow duplicate registration but there was a minor error. I'll update this thread as soon as it is fixed.
Thanks,
Tmaster100
Dec 07, 2016Aspirant
Mine has done the same.
- JohnRoDec 08, 2016NETGEAR Employee Retired
Thanks,
- Warkiller102Dec 08, 2016Initiate
Hello JohnRo,
thank you for the quick reply and deletion. :)
Best regards
Warkiller102- JohnRoDec 08, 2016NETGEAR Employee Retired
Hi Warkiller102,
You're welcome! I have checked your profile and it is cleared now. Tmaster100 still working on your registration issue, I have requested for deletion already but were still having some minor issues, it should be fixed soon.
Thanks,
- Apr 16, 2020Retired_Member
