martinezjr
Jan 31, 2018Aspirant
GS724v4 VLAN issue
So, I hate to beat a dead horse, but I can not get this to work.... I have connected, configured, reset, . . . over and over, searched the internet, searched this forum, read most(if not all) regarding VLANs on these devices, but I cannot get them to talk except on VLAN1.
Can somebody help me to know what I am doing wrong? Closest I can get to explaining is similiar to post https://community.netgear.com/t5/Smart-Plus-Click-Switches/Simple-VLAN-without-VLAN-aware-router-and-DHCP-aka-Port-based/m-p/1240717
Equipment and Setup
2 x GS724Tv4 (sw001, sw002)
1 x GS716Tv3 (sw003)
Connected in series via Port 1 and Port 2, ie: sw001 P2 to sw002 P1, sw002 P2 to sw003 P1, sw003 P2 to sw001 P1.
VLAN 1 10.100.177.0/24 (DHCP)
VLAN 10 192.168.0.0/24 (Static)
VLAN 20 192.168.10.0/24 (DHCP)
VLAN 30 192.168.2.0/24 (DHCP)
Ports 1 and 2 and SFP's on all switches are tagged with VLAN 1,10,20,30 with PVID 1
All other ports are set as "None", except as noted below: (untagged members, with respective PVID)
sw001 P3-18:1; P19-20:10; P21-22:20, P23-24:30
sw002 P3-12:1; P13-20:20; P21-24:30
sw003 P3-4:1; P5-8:20; P9-16:30
Well, it seems that like flipfl0p, it is just working now. I just did a factory reset, re-configure as stated below, ... the only thing that I did different was under System->Services->DHCP Snooping->Global Config, was to disable MAC Address Validation. I then reboot everything including the router(s) and it worked.
- martinezjrAspirant
- JohnC_VNETGEAR Employee Retired
Hi martinezjr,
Welcome to our community!
Thank you for sharing the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
