ianfloyd
Apr 22, 2022Follower
GS728TP drawing
Good Day,
Do you have a .dwg file, a high quality PDF or a orthographic line drawing of the GS728TP? Line drawings are quiet importnat for submittal purposes.
Thank you,
Ian
1 Reply
- DaneANETGEAR Employee Retired
Welcome to the community! 🙂
I'm sorry to inform you that there is no .dwg file, a high quality PDF nor a orthographic line drawing of the GS728TP switch.
You may want to check out the Visio Stencil for the GS728TP switch here. Be informed that there is a subscription required.
DaneA
NETGEAR Community Team
