smartfreenas
May 25, 2026Aspirant
GS728TP v1 failed update
Can you tell me if it's possible to restore the GS728TP v1 after a failed update? The firmware was 6.0.1.14. I updated to the latest firmware 6.0.1.30 via SCC (Smart Control Center). SCC (Smart...
May 26, 2026Guru - Experienced User
Does pressing the reset button for 10 seconds change anything?
If the FW was applied correctly and acknowledged by the system and rebooted, something happened.
Might check with NG support and see if there are any thing they can help with.
