smartfreenas
May 25, 2026Aspirant
GS728TP v1 failed update
Can you tell me if it's possible to restore the GS728TP v1 after a failed update? The firmware was 6.0.1.14. I updated to the latest firmware 6.0.1.30 via SCC (Smart Control Center). SCC (Smart...
schumaku
May 28, 2026Guru - Experienced User
The image shared on ibb.com with the 2x5 pins reminds me more to a JTAG port. J2 with the notch on the 5x2 Dupont connector -might- be intended for plugging a RS-232 DB9 COM header cable designed for the mainboards with 2.0 mm pitch header pins. AT resp. Everex pinout.
- 5x2 Dupont connector, 2.0mm pitch
- AT/Everex pinout
I'd expect to find a an unpopulated 4-pin UART serial header on the motherboard (usually labelled as JP1, J3, or CONSOLE (wild guessing, JP1 or J1 most likely) near the main Broadcom SoC or flash memory).
The 4-Pin Internal Pinout
Netgear is highly consistent across their smart switch and router lines with their 4-pin internal layout. On the PCB, look for the square solder pad or the small arrow/number indicating Pin 1.
The standard pinout configuration runs as follows:
| Pin Number | Signal Name | Description |
| 1 | VCC / 3.3V | Power (Do NOT connect this to your serial adapter!) |
| 2 | RX | Data entering the switch |
| 3 | TX | Data exiting the switch |
| 4 | GND | Ground reference |
Critical Connection Guidelines
- Voltage Warning (TTL Levels): This header operates at 3.3V TTL logic levels, not RS232 levels. Connecting a standard 12V RS232 serial cable or DB9 adapter directly to these pins will permanently fry the switch's motherboard. You must use a USB-to-TTL adapter (such as an FTDI, CP2102, or PL2303 chip breakout board) configured to 3.3V mode.
- Leave VCC Disconnected: Never connect Pin 1 (VCC) to your USB-to-TTL adapter. The switch is already powered by its internal power supply. Connecting the adapter's 3.3V or 5V power line to this pin risks creating a voltage conflict that can damage both the switch and your computer's USB port.
- The RX/TX Cross: When wiring your USB-to-TTL adapter to the board, remember that the signals must cross over:
- Adapter GND $\rightarrow$ Switch GND (Pin 4)
- Adapter TX $\rightarrow$ Switch RX (Pin 2)
- Adapter RX $\rightarrow$ Switch TX (Pin 3)
Serial Terminal Settings
Once connected, open your preferred terminal emulator (PuTTY, Tera Term, Minicom) and configure your COM port to the following standard Netgear settings:
- Baud Rate: 115200 (Some older revisions of the GS728T use 9600, but 115200 is standard for modern firmware bootloaders)
- Data Bits: 8
- Parity: None
- Stop Bits: 1
- Flow Control: None
If you power on the switch while connected, you should instantly see the U-Boot or CFE bootloader decompression text scrolling across your screen.
smartfreenas
May 29, 2026Aspirant
Thanks for the reply!
There is indeed a 4-pin connector on the board: 3.3V signal 1, signal 2, ground.
I connected an oscilloscope to it and saw that there's constant packet exchange on signal 1, and there's constant packet exchange on signal 2.
On other devices I've restored, packet exchange was only on one signal pin.
Here, packet exchange is constant on signal 1 and signal 2.
I'm not entirely sure that this is a UART connector.
