Coldlance
Oct 18, 2024Aspirant
gs728tpp not working with wireless access point
I'm trying to get a wax214v2 WAP working with a gs728tpp switch, but it's not working. Devices on connected to the WAP have no access to the internet. Wired devices connected to the switch can not con...
BrianL
Oct 27, 2024NETGEAR Moderator
Hi Coldlance,
Can or have you tried pining the Switch IP address from the devices connected to the AP (WiFi)? Also, send the tech-support file of the switch via PM so I can have a look.
Kind regards,
BrianL
Coldlance
Oct 29, 2024Aspirant
Hey BrianL,
So pings from the AP to the switch - some packets make it and some are lost.
I tried to download(upload) the configuration file but I'm running into some similar to what this person is experiencing.
Thank you
ColdLance
- BrianLOct 29, 2024NETGEAR Moderator
- ColdlanceOct 30, 2024Aspirant
Yeah, I am at a lost to why there's packet losses. How is the AP working fine when directly connected to the router, but when connected to the switch it get's an IP address fine from the router and communication between the AP and switch just doesn't go?
The switch is at the latest firmware, 6.0.1.30.
- ColdlanceOct 31, 2024Aspirant
Hey BrianL
Thank you,
ColdLance
