Mariuszing's avatar
Mariuszing
Follower
Nov 30, 2020
GS728TXP with 10GBASE-T as normal Port
Hello,
Is it possible to use on GS728TXP the 10GBASE-T as normal port for example on a Notebook with 10GBASE-T ethernet port? The other 10GBASE-T port is remainig for another computer.  The both 10G-SFP+ could be attached on my Synology NAS RS1619xs.
The 24 port are for standard devices like TV, cam, ...
Currently I use the JGS524PE but without the performance of 10GBE and the GS728TXP is propably the better solution for me.
Thank you for your support.
1 Reply
  • schumaku's avatar
    schumaku
    In the S3300, the four uplink ports can work in either Stacking mode or in Ethernet mode.
    In the Device view:
    • By default those ports are in Stacking mode, and their color is gray.
    • When these ports are configured in Ethernet mode, then their color is blank (unless connected).
    System > Stacking > Advanced > Stack-port Configuration
    Ensure you select the correct unit (if stacked) and port to change the port from the default Stacking mode to the Ethernet mode.
    FMI: S3300 Smart Managed Pro Switch User Manual p.25 and p.80 ff.
ProSupport for Business
