SteveAlliance
Nov 03, 2020Aspirant
GS748Tv5 - Create an Internal and an External VLAN
Hi - a newbie here. I am trying to configure a GS748Tv5 switch to have an internal and an external VLAN and am not having any luck. Here's what I want to accomplish: VLAN 1 Port 41 only. I am...
- Nov 03, 2020
Take it like this: A computer, printer, consumer router LAN is always untagged. The assignment of frames flowing into the switch to a VLAN is done by the PVID, the frames from the VLAN assigned coming from the switch to these devices are untagged.
schumaku
Nov 03, 2020Guru - Experienced User
Hi Steve,
Can't see why and where you want or need to install any VLAN routing - the connection between the subnets is up to your firewall device, not the switch.
SteveAlliance wrote:VLAN100 (External)
Ports 1 through 4.
Port 1 connects to my Comcast Router.
Ports 2 and 3 connect to my external Firewall ports. Port 4 is empty. Ports 1 through 4 are Tagged.
Your Comcast router does work with tagged frames? Probably not.
Your firewall WAN ports (why ever you want two) are configured for tagging, too?
SteveAlliance wrote:VLAN200 (Internal)
Ports 5 through 48. Ports 5 through 46 are for my internal network (PC's, Printers, Projectors). Ports 47 and 48 connect to my internal Firewall ports. Ports 5 through 40 and 42 through 46 are Untagged. Ports 47 and 48 are Tagged
Both switch networks (VLANs) are simple L2 networks in this set-up.
- SteveAllianceNov 03, 2020Aspirant
schumaku -
This is where my newbieness rears it's head - The ports were tagged because from what I garnered from the online help it sounded like they should be. IP Routing done for the same reason. We have multiple internal and external firewall ports because of a redundant firewall solution.
I will untag the ports and delete the IP routing and see what happens when I plug things in on Saturday.
Thanks for the feedback!
- schumakuNov 03, 2020Guru - Experienced User
