SteveAlliance
Nov 03, 2020Aspirant
GS748Tv5 - Create an Internal and an External VLAN
Hi - a newbie here. I am trying to configure a GS748Tv5 switch to have an internal and an external VLAN and am not having any luck. Here's what I want to accomplish: VLAN 1 Port 41 only. I am...
- Nov 03, 2020
Take it like this: A computer, printer, consumer router LAN is always untagged. The assignment of frames flowing into the switch to a VLAN is done by the PVID, the frames from the VLAN assigned coming from the switch to these devices are untagged.
SteveAlliance
schumaku -
This is where my newbieness rears it's head - The ports were tagged because from what I garnered from the online help it sounded like they should be. IP Routing done for the same reason. We have multiple internal and external firewall ports because of a redundant firewall solution.
I will untag the ports and delete the IP routing and see what happens when I plug things in on Saturday.
Thanks for the feedback!
schumaku
Nov 03, 2020Guru - Experienced User
