BilloBaggy's avatar
BilloBaggy
Follower
Apr 20, 2022
GS752TP SFP Compatibility
Totally new to fiber, so appreciate any help on this.
We're installing data cabinet some distance from our existing wiring closet, and have spec'd a bunch of Trendnet switches (DIN Rail mountable with alarm-out features... otherwise would have gone with Netgear, but I digress...). We will be using the TI-MGBS10 SFP (1000Base-LX Industrial SFP Single-Mode LC Module,10km). The distance is less than 800 meters, and I was wondering if the Netgear AGM732F would be happy talking to our Trendnet GS752TP switch?
Any insights into the above would be appreciated.
Kind regards,
Bill
1 Reply
  • schumaku's avatar
    schumaku
    The AGM732F is spec'ed as SFP 1000Base-LX SingleMode 1310nm - so if the link is single.mode fiber, and the other end does use the same colour 1310nm, there is nothing stopping you from deploying this config
ProSupport for Business
