Randy53215's avatar
Randy53215
Follower
Nov 13, 2018
GS752TPV2 - Assigning a static IP address to home devices
Hello all, trying to find a solution here.... I have a decent amount of networking knowledge. But I feel like when you get into these sorts of switches the lingo changes. lol   Basically the issu...
  • JohnC_V's avatar
    Nov 14, 2018
    Hi Randy53215,
    Welcome to our community! :)
    GS752TPv2 is just a L2 switch and it doesn't support L3 capabilities. IP reservation is only applicable on routers and not on switches even on fully managed switch.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
