UncleMatt73's avatar
UncleMatt73
Initiate
Mar 05, 2026
GS752TPV3 "comcast uplink port"
Howdy All,
We have instrumented our first "new to us" Netgear switch for our classroom (to replace like 7 smaller switched that were scattered around) and I got it up and running, but realize that PORT 7 is the "uplink to our comcast router" port and now we're putting a new classroom computer onto that port, so I need to move the uplink line.
I tried changing the VLAN to include Port 48 and Port 39 (both free in our schema) and moved the network line, but the switch refused to route traffic.  I rebooted the switch (not reset, restart) to see if "coming up on the new line" would work, but no.
If I move the line back to port 7 (still in the VLAN) it resumes functionality.
I have checked the port configurations in the switch web admin, and they are identical.
I have checked the VLAN membership configuration, and all three ports are "U"ntagged, with the same attributes.
Any ideas?  Thanks in advance
  • Thanks for the help.  I found the source of the problem:
    I had reassigned the VLAN assignment in the VLAN management, but in the PORT management, the old VLAN was still assigned in the PVID.  Once I aligned them, things are working cleanly.
  • schumaku's avatar
    schumaku
    Hello UncleMatt73
    Have by accident one or multiple ports configured as [U]ntagged for multiple networks?
    Have set the correct PVID on the port so untagged frames are sent into the appropriate VLAN ?
    Any routing between the different VLANs involved?
    When referring to the Uplink port, is this a local definition, or talking about the port "marked" as uplink port in Netgear Insight?
  • StephenB's avatar
    Is the switch showing you normal ethernet status when you move the port?
