Tomasz_FLX
Dec 03, 2019Aspirant
GS752TS Long reset of Unit 2 switch.
Hellow,
I have two GS752TS switches in stack configuration. They are connected by SFP Direct Attach Cable AGC761.
Unit 1 as Management, Unit 2 as StackMember. Standbay staus unit2 - Opr Standby.
When I pull out the cable between the threads and reconnect it - unit 2 begins to restart and it takes quite a long time before it goes into operating mode.
Is this normal behavior?
Regards
Tomasz
Hi Tomasz_FLX,
Welcome to our community! :)
You may need to reboot both switches if you want it to connect again in the stack in order for it to elect its master. This is normal if you just reconnect it while the other switch is running.
John
NETGEAR Community Team
1 Reply
- JohnC_VNETGEAR Employee Retired
Hi Tomasz_FLX,
John
