pmapp
Oct 08, 2015Aspirant
GS752TXS FP_COUNTER_TABLE Error
Morning All, Switch: GS752TXS (running in a stack of 3 with 10gb DAC) Firmware: 6.1.0.27 We are getting the following errors constantly: <11> Oct 8 09:26:15 10.1.0.21-3 DRIVER[53846932]:...
- Oct 09, 2015
Hello pmapp,
I don't believe it is common to get these kind of errors on switches. If you can, I suggest to just reboot the stack and see if the errors will continue.
Thanks,
JohnRo
Oct 08, 2015NETGEAR Employee Retired
Hi pmapp,
Welcome to the community!
I see you are getting some errors on your switches, let me see if I can help you with this. Upon checking, it appears that these might be DMA erors (Direct Memory Access) on the motherboard(s) on one of the switches. This can also be caused by adding another hardware or module.I have some questions for me to be able to help you further:
1. How old are the swicthes?
2. How long have they been stacked?
3. What changes did you make on your network before experiencing these errors?
Looking forward to your response.
Thanks,
- pmappOct 09, 2015Aspirant
Hi JohnRo,
Thanks for the reply....
1. The switches are coming almost 3 years old.
2. They have been stacked since day one.
3. There have been no recent config changes, other than tagging\untagging ports for VLANS.
Thanks for your help.
- JohnRoOct 09, 2015NETGEAR Employee Retired
Hello pmapp,
Thanks,
- pmappOct 20, 2015Aspirant
Morning, and thanks for your reply.
I'm unable to reboot the stack until next week.
Once done, I'll report back on the outcome.
Thanks
