pmapp's avatar
pmapp
GS752TXS FP_COUNTER_TABLE Error
Morning All,   Switch: GS752TXS (running in a stack of 3 with 10gb DAC) Firmware: 6.1.0.27   We are getting the following errors constantly:   <11> Oct 8 09:26:15 10.1.0.21-3 DRIVER[53846932]:...
  • JohnRo's avatar
    JohnRo
    Oct 09, 2015
    Hello pmapp,
    I don't believe it is common to get these kind of errors on switches. If you can, I suggest to just reboot the stack and see if the errors will continue.
    Thanks,
ProSupport for Business
