Eaglehawk
Jun 17, 2017Apprentice
GSS108E firmware 1.0.0.10 upgrade loop
Well, after a few successful upgrades since the ARP debacle, I thought the upgrade to the 1.0.0.10 version would be a no brainer. Upgraded to the new ProSAFE Plus Utility 2.4.3, selected the GSS1...
- Jun 23, 2017
Swap unit arrived. It still had the 1.0.0.0 firmware. Followed the steps as per the 1.0.0.10 instructions for this firmware revision (as I still remember the TFTP problem).
Still had the same problem (The TFTP one, not the firmware loop). So I had to put manual arp entries in for the new switch to make it take the firmware upgrade. I thought this was fixed with the 2.4.3 version of ProSafe? Did I miss a step?
Anyway, all working now. Hope no one else has this issue :)
XavierLL
Jun 18, 2017NETGEAR Employee Retired
Hi Eaglehawk
I would suggest also to try to do an upgrade first to the 1.0.0.6 version and later on do the upgrade to 1.0.0.10 if you haven't try it yet.
https://kb.netgear.com/31087/GSS108E-Firmware-Version-1-0-0-6
If this doesn't work I would suggest you to open a chat / online with NETGEAR Support and let them know the status of the GSS108E switch.
Xavier Lleixa
NETGEAR CBU PLM
Eaglehawk
Jun 18, 2017Apprentice
I was already on 1.0.06 before the upgrade. I'll contact support.
- EaglehawkJun 21, 2017Apprentice
Online chat did a TeamView, then we tried the back of the switch reset. Swap out arranged.
- EaglehawkJun 23, 2017Apprentice
