antzac67's avatar
antzac67
GSS108E Switch is not supporting 4K media streaming
I'm new on this community and this is my first post. I have two GSS108E Netgear Switches at home, one is dedicated to data and the second one is for TV boxes that now come with ethernet port and not with coaxial connector anymore.
There are 5 TV boxes connected to the switch, two of them are 4k the other 3 are HD. The HD boxes work fine but the 4k boxes send a pixelated image to the TV, I have done several tests to discard problems with the wiring, TV's or HDMI cables. After all the testing, I have concluded that my switch is creating the problem. As a test, I have replaced the GSS108E switch for a Linksys SE3005 and it worked fine, in fact I have connected a RJ45 couple adapter in the Switch position and the pixelated video disappeared. As additional info, I have upgraded my switch to the most recent firmware version and I have not change any settings form the factory defaults on my Netgear Switch, except the static IP. The TV/ internet carrier has suggested that my switch should be IPTV. ??? I have never heard the term.
I wonder if I made a wrong decision when I bought this switch or there are some settings in the switch that can help to solve this issue. Any suggestions or ideas will be appreciated. Thanks
    • antzac67's avatar
      antzac67
      Thanks for your post, I have checked the settings you mentioned and they are and has been as you suggested. So it seems the problem should be something else.
      Antonio
      • schumaku's avatar
        schumaku
        It might be required to update the unknown firmware on the GSS108E switches to enhance the ICMP Multicast handling - trouble is that Netgear has revoked firmware and some mandatory bootloader updates from the support downloads. YeZ please.
ProSupport for Business
