julzzw
Feb 20, 2019Aspirant
GSS108EPP Weight
Just after some firsthand info regarding the GSS108EPP ProSafe Plus POE+ Click Switch.
Just wanting to find out the correct weight of the unit. The product sheet says 3.2kg but at this page on ...
- Mar 01, 2019
The engineering team confirmed that the correct weight of the switch is 0.93kgs(2.05lbs). Sorry for the confusion.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Feb 28, 2019NETGEAR Employee Retired
Hi julzzw,
Welcome to our community! :)
I inquired your case to our higher tier to determine the correct weight of the switch. I guess the 3.20kg is actually the whole package like it includes the box and accessories(if there is).
- julzzwFeb 28, 2019Aspirant
Thanks John.
I do wonder what the extra 2.2kg in the package is, thats some heavy boxes! I mean maybe that is the mounting track, plus the two AU and US Fig 8 cables, which would add up I suppose.
Thanks again for following up!
- JohnC_VMar 01, 2019NETGEAR Employee Retired
