julzzw's avatar
julzzw
GSS108EPP Weight
Just after some firsthand info regarding the GSS108EPP ProSafe Plus POE+ Click Switch.   Just wanting to find out the correct weight of the unit. The product sheet says 3.2kg but at this page on ...
  • JohnC_V's avatar
    JohnC_V
    Mar 01, 2019
    julzzw,
    The engineering team confirmed that the correct weight of the switch is 0.93kgs(2.05lbs). Sorry for the confusion.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
