felithomas
Sep 12, 2019Aspirant
GSS116E locking tab problem
The locking tab assembly came off and I can't seem to know how to put the spring back so that it can work. Does anyone know how the spring fits in with the other two parts that are under the rectangu...
- Sep 15, 2019
Wild guessing - the spring has to go into the hole in the metal part (either from the top or from below).
felithomas
Sep 17, 2019Aspirant
BEST WILD guess ever! It worked! Thank you so much.
schumaku
Sep 17, 2019Guru - Experienced User
Your documentation (the photo) helped a lot! Thank you, too.
