trweiss's avatar
trweiss
Having trouble with VLAN setup
I have the Smart w/ optional Cloud (GS108Tv3) switch (software up-to-date at 7.0.9.19) connected to my Firewalla Gold SE router. Port 1 on the router is physically connected to Port 1 on the switch. ...
  • trweiss's avatar
    trweiss
    Feb 25, 2024
    I came for help and learned that I have "missing bits on the learning curve". Well spotted! Well spotted, indeed! Is that all it takes to be an "experienced user" and "guru"?
    Luckily, I was able to figure this out for myself. In case anyone is in a similar situation, here is the solution:
    On the switch, VLAN 1 looks like this:  UUUUUUU□.
    On the switch, VLAN 97 looks like this: T□□□□□□U.
    In PVID config, g1 has PVID 1 and is a member of 1 and 97.
ProSupport for Business
