trweiss
Feb 24, 2024Aspirant
Having trouble with VLAN setup
I have the Smart w/ optional Cloud (GS108Tv3) switch (software up-to-date at 7.0.9.19) connected to my Firewalla Gold SE router. Port 1 on the router is physically connected to Port 1 on the switch. ...
- Feb 25, 2024
I came for help and learned that I have "missing bits on the learning curve". Well spotted! Well spotted, indeed! Is that all it takes to be an "experienced user" and "guru"?
Luckily, I was able to figure this out for myself. In case anyone is in a similar situation, here is the solution:
On the switch, VLAN 1 looks like this: UUUUUUU□.
On the switch, VLAN 97 looks like this: T□□□□□□U.
In PVID config, g1 has PVID 1 and is a member of 1 and 97.
trweiss
Feb 25, 2024Aspirant
schumaku
Feb 25, 2024Guru - Experienced User
Perfect!
schumaku wrote:
How does the security appliance/router is supposed to bring the VLAN 97 to the switch? With a dedicated physical link and port, or as part of a trunk carrying VLAN 1 untagged, and tagged for VLAN 97?
With only an access port number 8 untagged and PVID to VLAN 97 the job is not finished, and the new network isn't connected to anything else
For reasons, I had asked you two questions on your security appliance/router. Looks like Guru advise brought you ahead on your project. 8-)
In absence of the Crystal Ball, and your failure to tell us on how your environment is configured? Fairness where fairness belongs please.
