koa132435
Jul 16, 2022Star
HELP GS110EMX low Upload Speed when connecting at 2.5Gbps on ports 9 and 10
Hi All, I hope someone can help and point me in the right direction even though I think this is a software/hardware bug (I hope I am wrong). First - every time I connect on port 9 or 10 and c...
DaneA
Jul 20, 2022NETGEAR Employee Retired
What is the current firmware version of your GS110EMX? If ever its not yet the latest version, I suggest you to update it then observe if the same problem will occur. The latest GS110EMX firmware is v1.0.2.3 and you can download it here.
DaneA
NETGEAR Community Team
- koa132435Jul 27, 2022Star
The latest firmware, attached is the screen capture. Same problem.
Also, I connected an ASUS router's 2.5 Gbps port, and same problem with upload being throttled or rate limited.
The same problem across 2 x GS110EMX , and 1 x GS110MX. Monitoring on the switch and router shows 2.5 Gbps solid connection over 5ft of e Cat6 cables.
I already tried multiple cables, shielded and no shielded (The same 5ft cables work and support 10 Gbps with no problem).
- DaneAJul 28, 2022NETGEAR Employee Retired
Thank you for your response. Kindly try to enable Flow Control on ports 9 & 10 then observed if the same issue will occur.
DaneA
- koa132435Jul 29, 2022Star
I have exhausted all tests, enabling, disabling flow control, rate limiting,etc and same results.
I decide to find another switch, non-Netgear switch and the problem remained the same. So this ruled out the Netgear switch. I then decided to enable a shared folder in a desktop using a single 1 gbps port to eliminate the NAS device and I had the same problem with the upload speeds, it is capped/rate limited when I use the 2.5 Gbps port on the Netgear WIFI router.
At this point I may need to switch strategy and focus on the router, maybe the 2.5 Gbps speed on the LAN segment has a rate limiting đĄ.
Thank you DaneA
